Home > Maintenance & Mods (L322) > Draper Expert oil extractor Q |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3786 |
I have been using mine several years and it always empties the full 9 L + in one go.
16th Nov 2023 2:50pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
That's good to hear . I've done it hot and cold with same results always with the filler cap and oil filter off. Cold took ages but it did get nearly 10L out. Maybe I'll take it apart again and see if I can see anything as it's way easier not having to decant it into an empty container 1/2 way through. 2012 TDV8 Vogue (L322) |
16th Nov 2023 3:45pm |
The whole logic of buying an extractor with 10 L capacity is based on knowing you can suck it all out in one go without fear of spilling any, otherwise you may as well buy one of the various smaller capacity pumps that are much much cheaper..
16th Nov 2023 4:07pm |
Just had mine apart and couldn't se anything obviously wrong ( or anything to go wrong) but the lid seal was leaking slightly so re assembled it with some silicone grease and it seems to be holding so will give it a go this WE. 2012 TDV8 Vogue (L322) |
16th Nov 2023 5:02pm |
Oil change today and it failed again at 8L when the pump went stiff in both directions and wouldn't create any vacuum. The issue turned out to be a valve where the exterior black breather tube attaches to the base. Unscrew a plug and poke a small screwdiver in and a rubber 'thingy' on a small spring popped out and when pushed back it was working again. Some kind of one way valve but obviously a bit fragile. 2012 TDV8 Vogue (L322) |
17th Dec 2023 3:38pm |
