Home > In Car Electronics (L405) > GPS problem
yelnats6969
GPS problem
Help, My L405 GPS has suddenly lost all UK info and has switched to Europe, I can get into the system to change country but the UK is not listed.
It came up to say initialising as if it was a first time install, it seems that all UK info has delated, but every European country is listed except UK on the change country menu is not.
Is as if the EU maps have replaced the UK
Any ideas? is there any way to remove the GPS disk and re-insert? to get back to UK GPS
2013 Vogue 4.4D
Thanks Stan
Post #680409 15th Dec 2023 4:34pm
Phoenix
Post #680415 15th Dec 2023 5:19pm
yelnats6969
your reply message was blank
Post #681788 3rd Jan 2024 3:55pm
no disc on yours, i would try a battery disconnection and see if that re-boots the system..if it does then it will most likely default to belgium so you'll have to select GB/UK.. ... - .- -.
Post #681797 3rd Jan 2024 4:21pm
Kot
Re: GPS problem
2013 Vogue 4.4D
Thanks Stan
Brexit Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #681812 3rd Jan 2024 7:00pm
