Home > Maintenance & Mods (L405) > Spongy brakes
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
Spongy brakes
A well discussed topic I'm sure but seeking advice from knowledgeable members.
After changing my rear flexy pipes and brake pads the brake pedal feels fine till I start the engine , then it sinks to about half its travel. A couple of pumps and it's back to normal and the brakes are as sharp as ever but still the pedal feel spongy. I lost very little fluid when changing the flexys and I've bled the brakes about 4 times, twice with a pressure bleeder. Should I use the icarsoft to do whatever it does to the ABS unit and although I've already tried it should I have the engine running?
Been bleeding brakes for the best part of 60 years and the last time I had one like this it was a Ford Zephyr......in 1968. Any advice would make an old man very happy 😊.
Cheers
Pete
Post #680387 15th Dec 2023 3:02pm
Phoenix
Post #680394 15th Dec 2023 3:59pm
Gremlin500
@Phoenix:
THAT sounds like a very er, sound Embarassed bit of advice! Thumbs Up
Makes perfect sense, in fact.
I had a lot of bleeding trouble ( Laughing ) last year, when I replaced all four flexibles, using a pressure bleeder and got through loads of brake fluid. Even my local indy who finished the job off for me, had a bit of difficulty, and eventually had to run the ABS pump to get it sorted.
(I’d clamped off the hoses during swapping out all the brakes, but it was stood for days waiting for the wrong rear brackets to be replaced, so maybe air got in then).
Sorry I rambled a bit there, but getting back to the point, a decent flow is what does the job, as you say! Bow down ā€œIf it ain’t broke, don’t fix itā€ -where’s the fun in that?
Post #680405 15th Dec 2023 5:06pm
D3Jon
Phoenix wrote:
<snip> Connect pressure bleeder but do a manual bleed using the brake pedal, pump as fast as you can to displace air bubbles from the 'high points' in the pipework.
Bleeding at the 2 - 2.5bar the pressure bleeder works at doesn't provide enough flow rate to displace the small air bubbles, pressure and pumping the pedal does.
100% agree with Phoenix - pressure bleed + pump pedal.
Had issues with bleeding a Vauxhall van the other day. Used the vacuum bleeder after changing a caliper - no good. Air had got well into it, even though hoses were clamped off - but left a couple of days whilst caliper was exchanged.
Got out the pressure bleeder running at 30psi, still couldn't get a decent pedal, it was clear there was air somewhere in there!
Pressure bleeder + pumping of pedal with bleed nipple removed (carefully watch reservoir / pressure bleeder fluid levels) made for a rock hard brake pedal!
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #680410 15th Dec 2023 5:54pm
Phoenix
Post #680414 15th Dec 2023 6:15pm
Spridget
Thanks for the info lads. I'll have another go at it tomorrow, weather permitting and report back. I had thought of pushing the pistons back into the calipers to get rid of an extra hiding place and even taking the calipers off to position the bleed nipple right at the top like you sometimes have to do with motorbikes but as has been stated I think the air is hiding in the roller coaster.
Thanks again
Post #680417 15th Dec 2023 8:04pm
Spridget
Thanks again
Why do I always post it twice??? Embarassed Never had this bother in the days of the Zephyr. Crying or Very sad
Post #680418 15th Dec 2023 8:05pm
Phoenix
Post #680420 15th Dec 2023 8:09pm
Spridget
'Happiness is a firm pedal'. Well more firm anyway. Bled the brakes using the fast pump and pressure bleeder method. The pedal is much better now, rock solid with very little play with the engine off. Start the engine and it sinks a bit, which is normal but then it still feels a bit spongy, more than my other cars. My good Lady says it's me being a faff and she's fed up pumping brakes so I'll see how it goes.
Next job is to fit a towbar but that might be for the Spring.
Thanks again.
Post #680461 16th Dec 2023 3:20pm
Phoenix
Post #680466 16th Dec 2023 3:47pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Had quite a few of these play up after new hoses / pipes, try bleeding it with he engine running, it does make a difference Thumbs Up
Post #680692 18th Dec 2023 9:04pm
Spridget
That is the plan. I'm still not 100% happy with them but there's only so many times you can bleed them. On the run the brakes are fine ......just still a bit spongy. Engine running and 28 pumps as per the manual at the next opportunity Rolling Eyes.
Post #680716 19th Dec 2023 9:58am
Phoenix
Post #680717 19th Dec 2023 10:04am
Spridget
Bled the brakes AGAIN with the engine running as per the manual. Still the pedal is rock solid with the engine off but it sinks to about 50% when I start the engine. I'm beginning to wonder if this is how they should be, the brakes are brilliant on the road and the first 50% gives very progressive braking so even in the soft zone it. Maybe I'm just used to older braking systems.
I have the 2 bleed nipples on the MC Phoenix so that could be the next port of call and if that and one final bleed of all 4 corners when my new pressure bleeder arrives ( Old one was home made and after much faithful service has developed a leak ) I'll try to convince myself that there's nothing wrong with it.......although I might ask my local indie what he thinks next time I'm through there.
Post #680829 20th Dec 2023 5:09pm
Phoenix
Post #680830 20th Dec 2023 5:37pm
