Home > Technical (L322) > Suspension Fault - advice sought
camcc
Evening all,
Went to start the RR this afternoon and it would barely crank. It turned off the ignition and tried again - it was the same but she fired up. Rev counter did nothing for about 5 seconds then came to life - doesn't normally do that.
I could hear an intermitted tick ... 3 seconds ... tick ... 3 seconds ... tick ... from the back of the car and then the following suspension fault appeared on the dash. Lights on the centre console height switcher flashed for a bit then went out completely.
I plugged in the GAP tool which showed a battery voltage of 12.5V and the following fault code:
U2007-67 (AF) Valve(s) circuit - Algorithm based failure - signal is incorrect after the event
Surprisingly not much on Google when searching for this fault!
Took my other car out for a few hours and started the RR again when I got back. Fired up no issues this time but the suspension fault is still there.
Any advice / thoughts appreciated!
Post #679999 10th Dec 2023 6:42pm
Merchy
If you get a low battery voltage on these cars this causes all kinds of fault indications.
Try a steering angle sensor reset before going any further - with car running turn to steering to full lock one way, hold for three seconds, the go to centre, hold, opposite lock, hold, and then back to centre and hold.
I work away for long periods of time and then usually have to charge up my battery, when the voltage drops I get suspension faults, plus ABS faults etc, after a good charge, running the car at idle for a while and carrying out this reset and moving the car back and to over a few yards has always eliminated all the indicated faults.
Post #680003 10th Dec 2023 8:09pm
camcc
Thanks! Steering angle sensor reset didn't solve the issue unfortunately.
Since the battery voltage is quite low, I've ordered a new one (Varta I1 110AH), so will post an update once it's fitted and faults cleared.
Post #680138 12th Dec 2023 2:04pm
camcc
A new battery solved the issue! Old battery was down to about 40% charge when I tested it Shocked
I may have a battery drain which I will spend some time trying to identify this weekend.
Post #680359 14th Dec 2023 9:33pm
dhallworth
It's cold at this time of year and if you don't use your car much, especially on a car that's as heavy on electrics as the RR, it's easy for a battery to become discharged.
Your old one might well recover if left on a charger overnight if you wanted to keep it as a spare.
Post #680363 15th Dec 2023 12:02am
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
(Varta I1 110AH)what is the cranking amps, mine is 800 RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #680365 15th Dec 2023 5:54am
camcc
David.
Thanks! Will try that.
920
Post #680549 17th Dec 2023 5:37pm
