Home > Technical (L322) > Late L322 Ford Era Fan Noise From Behind Glovebox 2012 |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 606 |
Hi,
8th Dec 2023 8:03pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1209 |
One possibility is that the noise could be coming from the climate control panel, not sure about your year car, but some control panels have a small fan built into the panel, maybe a possibility ? |
8th Dec 2023 8:25pm |
Hi,
8th Dec 2023 9:15pm |
If it's narrowed down to the climate control panel, removal of the panels is easy, but do it gently as there is an ECU built into the panel that controls all climate functions.
8th Dec 2023 9:57pm |
OK, thanks, I'll see if I can narrow it down further.
8th Dec 2023 10:03pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
There's also a fan in the audio head unit.
9th Dec 2023 10:33pm |
KF Member Since: 19 Jul 2022 Location: Kerava Posts: 43 |
I might know what you´re after, although have no answer, unfortunately.
10th Dec 2023 7:53am |
Hi,
10th Dec 2023 9:36am |
Hi,
14th Dec 2023 2:41pm |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 876 |
Good to hear you’ve located the source of the hum although just to confirm it was the FBH fan after all, as not familiar with an FDR fan? Jonathan
15th Dec 2023 10:47am |
Yes sorry, to clarify its the FBH water circulation pump on the FBH itself.
15th Dec 2023 12:57pm |
