Home > Maintenance & Mods (L405) > L405 Airbag Light
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
L405 Airbag Light
Evening All,
After some advice please, after dragging the L405 out for a spin this evening the airbag light came on whilst sitting stationary in traffic.
I don't have an IID tool so after some guidance were to start looking, from memory wiring under seat maybe??
Thanks in advance
DrF
Post #679667 6th Dec 2023 10:15pm
Phoenix
Post #679669 6th Dec 2023 10:33pm
DrF
Thanks Phoenix,
Ok, now I do have an Autel fault reader that works on my Bentley and Ferrari so I assume that will read faults on L405 as well? Never tried so I shall
Post #679670 6th Dec 2023 10:41pm
Phoenix
Post #679671 6th Dec 2023 10:45pm
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
Ive had this happen a couple of times, especially on start up. In my case the solution lies under the passenger seat. There is a large connector. Dont open it, just wiggle it around, the light goes out.its worth remembering that because the light is on the nearside of the dash, there is only one light for the whole system. I have heard people say that its only the nearside airbag.
Should add that I discovered this fix on here, so credit and respect to the knowledgeable ones. 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #679706 7th Dec 2023 5:17pm
DrF
Thank you, when it stops raining i will have a fiddle Thumbs Up Thumbs Up
Post #679734 7th Dec 2023 8:27pm
DrF, Move the drivers seat around, grab the wiring loom under the seat and give it a wiggle! Usually works Thumbs Up
Post #679740 7th Dec 2023 8:39pm
DrF
Thank you, will do and report back Thumbs Up Thumbs Up
Post #679756 7th Dec 2023 10:49pm
That's what I like about this forum, such precise and technical resolutions.... Thumbs Up Bow down Thumbs Up Pete
Post #679757 7th Dec 2023 10:56pm
DrF
Evening all,
I am please to confirm that a good poke and prod and moving of passenger seat and hey presto airbag light now gone out. I did notice that one of the numerous wiring looms under the passenger seat had popped out of its clamp, so popped it back and ensured all plugs pushed home and job done.
Thank you as always.
DrF
Post #679850 9th Dec 2023 1:32am
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
I'm having the same problem and the iCarsoft directed me to Right, side airbag B0028-13. Sure enough a good wiggle and moving the seat back and forward and it went away, no doubt to return at a later date. There's loads of info on the internet about fault finding on SRS and I notice that Famous 5 do a new part harness which links the underseat connector to the side air bag Part No FF012191. Hopefully it won't come to that as it seems to be a bit like defusing a bomb Shocked
Post #679910 9th Dec 2023 8:55pm
