![]() | Home > My Range Rover > My New L322 4.4 V8 ('53) |
24valve Member Since: 07 Apr 2009 Location: Cornwall Posts: 165 ![]() ![]() ![]() |
Nice!
jamiej Member Since: 01 Dec 2023 Location: Surrey Posts: 59 ![]() ![]() ![]() |
Little update on this.
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 907 ![]() ![]() ![]() |
Ref the leak, whereabouts is it appearing inside the car?
It's running down the drivers A pillar, through the light control unit and the puddling under the kick plate where a 2 inch diameter of cable is running.
Classic sunroof drain issue, could there have been any remaining water in the sunroof tray (accessible with the sunroof open) before you taped it up and it’s the last of that water working it’s way through? Jonathan
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7909 ![]() ![]() ![]() |
The speedo feeds from the rear left ABS sensor. Had this on my TD6. I then made the mistake of clearing the faults without fixing the issue……That then caused a few faults plus the car will think it’s not moving when it is, ie it will see 3 wheels turning and no speed increase so it assumes wheels are spinning, so winds back engine power… it didn’t see that working so it applied abs…. So whenever I set off, the car braked to a standstill 🤣. Ended up being the reluctor ring on the driveshaft going rusty. Needed a new driveshaft but I now understand you can get the rings separately now. See what you find at the rear left wheel.
Sorry to hear of the problems - It does sound like the drains are blocked. That wasnt something I had a problem with as it only ever came out on decent days and was kept in the garage. We used the td6 as the workhorse, and I did have problems with water getting inside in that - mostly getting in behind the fusebox behind the glovebox, or in the rear amp/pdc area.
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 168 ![]() ![]() ![]() |
I had a similar experience to you as a new L322 owner. I searched for the cleanest example I could find with ivory leather and things like HK, heated and cooled seats, no prior bodywork repairs, low mileage and ok history. I purchased from a non specialist dealer and paid very good money but happy I had likely found one of the best available.
double post |
I had the car looked over by a specialist (SLR in Surrey) who didn't notice any show stoppers and that it "was a good one".
Small update on this.
MOT all passed, with no show stopping advisories.
