Home > Maintenance & Mods (L405) > FBH stopped working
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
FBH stopped working
Afternoon all,
Frustratingly my FBH has stopped working. The car has batteries on that are only a month old and the car has few short journeys, and the fuel tank is over 50% full. It has worked before (only on timed climate as I cant get a remote to pair). Any ideas? I'm assuming there will be a fuse or two to check, anything else? It is going in for a LR service at the beginning of Jan so if it isnt sorted prior to then I can ask them to look at it on the extended warranty
Arch First time FFRR owner
Post #679417 4th Dec 2023 1:52pm
caymanblack
Is it still cold enough up there? overfinch modified
Post #679426 4th Dec 2023 4:07pm
Phoenix
Post #679430 4th Dec 2023 4:28pm
Arch Stanton
no DTC codes listed with an Autel check Phoenix, and it was covered in snow at the time Cayman so I'd guess it was cold enough to be active
I've given it an hour runaround this evening and set the timed climate to come on in the morning for a trip to Penrith. First time FFRR owner
Post #679483 4th Dec 2023 10:26pm
Phoenix
Post #679484 4th Dec 2023 10:47pm
Arch Stanton
I dont play with the Autel much so am a bit of a divvy but I think there is an option to read live data but I didnt go to that option. First time FFRR owner
Post #679494 4th Dec 2023 11:41pm
