![]() | Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322 |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Have you got the part number for the paddles? Only ones on the bay are £110. |
hi matt, glad to see yours is all done, |
stonosam Member Since: 01 Apr 2009 Location: Sydney Posts: 24 ![]() ![]() |
Is there any specific reason why a dealer can't edit the CCF file? Or is it simply a case of they could do so but won't. Anybody know if someone has the required equipment in Sydney? |
Baben Member Since: 17 Oct 2010 Location: Kyalami Posts: 165 ![]() ![]() ![]() |
AFAIK the dealer equipment just can't access anything that is not fitted as a standard feature on the vehicle.
Jsb Member Since: 24 Nov 2010 Location: Southampton Posts: 78 ![]() ![]() ![]() |
just a thought, but i got a new heated wheel in the new shiney soft leather with chrome spokes and paddles for 170 from this guy :
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
just use small bits of green acetate, its the same as sweet wrappers but thicker,they use in theaters over the lights
yes im gonna go for a wireless module but unfortunatley for me i have no idea how to do it using one of those as all the ones i see in maplins seem to have remotes like this one http://cgi.ebay.co.uk/2-CHANNEL-RF-WIRELES...2eb58e7db5.....with regards to the green tint im gonna get some lighting film off of one of the film sets im working on that should do the job well |
thats the item you need, what you have to do is mod the paddles to make them work as an open/close switch, then the the remote from maplins is modded by removing the switches and soldering the wires from the paddles to the points where the switches are soldered to the board. V8 facelift Range Rover Autobiography 22" wheels.
ive allready modded the paddles and got the power hard wired to them (i even tested them to make sure they work which they do) its just a case of getting the wires to the box now......with the wireless thing do i use the remote as the sender on the paddles? "RANGEISM WILL NOT BE TOLERATED"
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
Hi pretlove, what you need to do with the remote sender is dismantle the sender unit, use a soldering iron to carefully remove the 2 channel buttons (one big and one small) then you need to split the one ground connection from the paddle shift loom into 3, 1 for channel 1, 1 for channel 2 and 1 for connecting to the ground on the steering wheel controls.
matt, did you not do a video of this... V8 facelift Range Rover Autobiography 22" wheels.
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Why not order a spare transmitter and hand it to your rear passengers, that way you can all be involved with the driving, it would certainly make pulling onto a busy roundabout all the more exciting when you discover your mate has selected 6th |
![]() @ matt and dave thanks guys i think i get the idea now ![]() www.futuresecurityservices.co.uk Pretlove says , '' I want my car back ![]() |
