Home > In Car Electronics (L405) > Just want to check this before I replace fuses! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35358 |
i had a similar problem with my old westie....the power sockets wouldnt 'supply' voltage to any accessories plugged into them until, like you, i shut down and re-opened the FF again.
30th Nov 2023 1:34pm |
DamianK Member Since: 04 Aug 2023 Location: West Sussex Posts: 58 |
Well thats what I thought it could be so I too replaced the battery but it hasn't helped - unless there is something I need to reset after replacing it? |
30th Nov 2023 2:04pm |
its recommended by the WM that you 'tell' the FF a new battery has been fitted , but, some members havnt done this and claim their FF is fine.. ... - .- -.
30th Nov 2023 2:36pm |
How do I do that? |
30th Nov 2023 2:52pm |
If my previous battery was getting low (I had no warnings though and only changed it to see if would fix this issue, I figured the car was 6 years old so it couldn't hurt generally either!) and the car was prioritising starting the engine etc and not supplying sufficient oomph to the USB's, when I changed (well Halfords) the battery is it possible the car is still not sending the correct voltage to the USB's as it still thinks the battery is low or is that all just rubbish and it doesn't work like that. Getting to the bottom of this has become a bit of a fixation as it seems to make little sense! |
30th Nov 2023 4:55pm |
Bit of an update - today, for the first time since I have owned the car, the USB connected to my phone on first start up! The big difference from normal was I was in the car for a good few hours yesterday driving, so I am wondering if that if the car sits for a day or two then the battery is maybe dipping (although it has a new battery but maybe the car doesn't 'know' it has a new battery and I need to get the car to register the new battery)
4th Dec 2023 4:29pm |
