![]() | Home > My Range Rover > Moved from a D3 to a Mk3 L322. The problems begins! |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
Leaky a/c: get it fixed😂
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4323 ![]() ![]() ![]() |
Water in boot:
Fla Member Since: 26 Nov 2023 Location: South west Posts: 189 ![]() ![]() ![]() |
Hi thanks for the info. Ya I’ve been using the wiki a lot and have plenty of paths I can take with each issue. My D3 had a lot of small problems and it was a pleasure to fix them all one by one. I bought this one as there were only 3 4.4s in Ireland and I got a good deal on this.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3870 ![]() ![]() ![]() |
The advice to bin the steps maybe a little premature (I also have another half who can't manage without them). I got mine cleaned and lubricated by an Indy and all is well, others have lubricated the steps to good effect. Certainly worth a try, if you are able to remove them and find a skip then you are more than capable of trying a bit of lube first. Geoff |
Hi Super
I'm a bit to old and creaky to do work on the car myself, neither am I ready for the skip. However I think the motors are OK but the pivot points need lubing. This thread may help
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 400 ![]() ![]() ![]() |
For the leaky boot - if you have a tow bar fitted check the water is not coming in through the bolt holes that join the bar to the body - the water can run down from the top of the car and end up finding its way in there - other than that the rear tailgate seal is a potential culprit.
Thanks for that info. No Tow bar yet, that's a joyful job I have to do myself soon so will be looking in Wiki for advice!
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 890 ![]() ![]() ![]() |
With no tow bar currently fitted, per advice above my money is strongly on the tailgate seal - unfortunately not particularly cheap from LR, however order from Duckworth LR Market Rasen for a forum discount & free next day postage.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Can you elaborate, are you saying it's a two door L322..!! or it has no rear seats... How does this effect access..? That's a short list of issues for a 322, and all solvable... I'd take the steps off, strip them down as much as you can and use motorcycle chain lube on all moving parts, it tends to hang around longer than a lot of other stuff... ![]() I now have permission from the boss to use Y.O.L.O. Enjoy life __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35489 ![]() ![]() |
''2 seater''......
Thanks Haylands, thats a great TIP about the chain oil. Ya in fairness the guys previous had no idea about the car so they brought it to the garage to fix everything so the issues are all minor and repairable at home. I have a full set up to do most of it myself.
Thanks for clearing that up, if you move the seat all the way forward I guess you can reach the rear bolts, then the fronts, couple of connectors and you can remove the seat, 10min job... hopefully in yours....
haha ya airbag in the face is always bad even on the weekends! I have an Autel Maxicom808 so faults are ok to clear. I've had the seats out in the disco half a dozen times to used to the process but these seats look twice as heavy.. |
