Home > Maintenance & Mods (L322) > Bonnet in service mode tool
Wiltshire130
United Kingdom 2018 Range Rover Autobiography 5.0 SC V8 Corris Grey
I am sure I am not the only person who has experienced this problem.
Most YouTube videos show the gas struts being disconnected at the wing (lower) ball joint to allow the bonnet to be raised to the service mode.
The problem comes if you are working solo is when you come to lower it the struts hang vertically and hit the wing top on the opposite side to the one you are standing and prevent the bonnet being lowered to allow engagement of the first strut.
To overcome this I have made a small device which clips in to the punched holes in the inner face of the bonnet to retain the struts but which allows for easy connection and disconnection. No vehicle modification is required.
I have attached pictures which will no doubt make more sense than the words.
I can manufacture more if anyone is interested.
Post #678720 25th Nov 2023 7:49pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Good idea, and yes it’s a faff to single-handedly refit and lower the bonnet down.
I use a couple of small metal ‘S’ shaped hooks to effectively do the same thing. Hand/rest each gas strut in the hook and it stops the struts tricking the wings when lowering the bonnet. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #678744 26th Nov 2023 9:58am
Baltic Blue
Another Baltic blue one, but my solution is a bit more Heath Robinson Rolling with laughter
Post #678745 26th Nov 2023 10:23am
excellent idea.. Laughing Thumbs Up
heres mine,
Post #678746 26th Nov 2023 10:42am
I know which one of you is winning the prize for beautiful engineering Laughing
Post #678768 26th Nov 2023 4:00pm
my R&D dept worked for at least 10 seconds on my solution... Mr. Green ... - .- -.
Post #678771 26th Nov 2023 4:12pm
Baltic Blue
I concede defeat to our friend from Wiltshire Bow down
Please can I be your first customer if you make some more .
Cheers
Post #678772 26th Nov 2023 4:34pm
Laughing
i 'wooden' know where to start Mike... ... - .- -.
Post #678773 26th Nov 2023 4:38pm
Baltic Blue
We should send him a copy of the W.M. as a winner’s prize Wink
Post #678774 26th Nov 2023 5:13pm
I always used to lift the strut up on the first side and tuck it under the corner of the bonnet insulation which holds it in place really well, then do the other side etc etc...
Easy, quick and nothing else needed... Thumbs Up Pete
Post #678777 26th Nov 2023 5:42pm
