Home > Maintenance & Mods (L322) > FBH circulatin pump
dazk2001
United Kingdom 2008 Range Rover Vogue SE TDV8 Stornoway Grey
FBH circulatin pump
question about fbh got a fault code 0x0304 Circulation Pump - Open circuit or short circuit to battery
is this the circulation pump on the webasto or another pump
any help appreciated as to what the fault may be 2008 Range Rover 3.6 TDV8 Vogue SE
Post #678743 26th Nov 2023 8:25am
Dutchgit
Germany 2008 Range Rover Vogue TDV8 Stornoway Grey
It's on the webasto.
found an image on Evil Bay where you can see it in the first picture where they cut off the coolant line.
https://www.ebay.co.uk/itm/303493036876
It's the thing with the lowest hose cut off.
Post #678790 26th Nov 2023 7:24pm
