![]() | Home > Technical (L405) > Deployable Side Steps Lubrication |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3858 ![]() ![]() ![]() |
If this is some sort of warranty thing I bet it doesn’t apply to 10 year old vehicles - like mine |
The front offside bracket for my deployable steps has broken is this available as a part or will I have to fit new steps. Obviously if anyone has one for sale I would be interested. Geoff |
Bump to remind you Craig Geoff |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Sorry Geoff the one I have left is a rear one with a motor attached… 🙏 |
Geoff, are you still looking for one? I have one here if you are sir… |
Thanks Craig - it would appear not - just had car into Indy and I specifically asked them to check the knuckles for cracks (it was in for its MOT) and that front bracket, they gave it a clean bill of health on both counts and attended to both the side steps and the deployable towbar and got them both working perfectly. They still took 800 quid off me but there was a big sevice as well. Geoff |
Thanks for letting me know sir… 👍 |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 ![]() ![]() ![]() |
just been reading this thread, i do not think you need to apologise gremlin, I have the same problem, daughter rang me one morning to ask could i be at home to accept a delivery, ( told me, don't worry it's only one item and cut the call )what was delivered ? A full electric, folding, super duper treadmill, took three of us to lift the box from the wagon into the garage, then this muppet had to assemble it |
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 287 ![]() ![]() ![]() |
I was having similar problems with the steps.
Suki Member Since: 21 Oct 2022 Location: London Posts: 15 ![]() ![]() ![]() |
Reviving this old thead in case it helps someone. I have read lots from people who have had different issues with the steps being stuck. In my case, this was exactly as luxmoggy describes: the step is stuck in the out posistion, and when I open the door it jumps. When I close the door it doesn't jump. No amount of pushing the step did anything. On the main screen, it intermittently showed a message saying that there was an obstruction detected. This was the fix - Clean, lubricate and reset the side steps: Pressure washed and dried the mechanism. Used wd-40 and then copper grease anti-seize spray on the hinges. To reset the steps, open the drivers door and wait for all illumination on the srcreen or dash to power-down. Remove the spare wheel to reveal the battery. Remove the negative terminal and wait 10 mins. Reconnect the terminal, and start the car. Leave a few mins and then operate the door. This worked for me - hope this helps. |
