Home > Maintenance & Mods (L322) > Design pack rear bumper
kevinp
I'm thinking of putting a design pack rear bumper on my car and I'm trying to find out if the standard Westfalia detachable towbar has enough clearance or do you have to remove the centre section of the bumper when hitching up?
https://www.powerfuluk.com/cdn/shop/produc...width=1426
Post #678327 20th Nov 2023 12:38pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
I think the middle section is so you can remove that part from the frame.
I have a copy bumper that does not have the cutout.
Post #678400 20th Nov 2023 11:54pm
kevinp
Thanks JNC. Do you know the make of your bumper?
Post #678401 21st Nov 2023 12:08am
JNC
Fibreglass mix of overfinch and design pack.
Meduza. It's what it came with, would prefer OE bumper.
Post #678403 21st Nov 2023 12:38am
kevinp
Powerful UK have just had stock of the bumpers again and have said the undertray 'might' need modifying to allow fitting of the towball. Thanks.
Post #678408 21st Nov 2023 3:31am
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
I have the design pack with a detachable tow ball and the grey cover does need a small rectangular section cutting out where the receiver is located - there’s a mark moulded into the panel showing where the cut needs to be made.
The cover itself shouldn’t need removing when towing Thumbs Up
 Jonathan
2007 Defender 90 XS Hardtop
Post #678409 21st Nov 2023 5:55am
kevinp
Thanks Jon. Thumbs Up
Post #678410 21st Nov 2023 7:22am
