Home > Maintenance & Mods (L322) > Tdv8 losing drive |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Have you checked the pivot where the selector cable attaches to the lever on the side of the transmission is free to rotate? |
19th Nov 2023 8:27am |
Wk52RR Member Since: 29 Dec 2020 Location: Devon Posts: 54 |
Yes this appears to work correctly. I believe it selects gear fine, when it loses drive and starts making the whirring noise it still displays D in the instrument cluster and if revved to 3500-4000rpm it very slowly starts moving (the speed it moves is about half the speed of first gear low range at idle) |
19th Nov 2023 9:55am |
Draw off a bit of transmission oil and check for metal flecks, it could be the torque converter on it's way out or something more serious. |
19th Nov 2023 12:12pm |
Funny enough I did that this morning. Couldn’t see any metal but the oil is pitch black and the car has only done 115,000miles. Changed the oil in zf6 gearboxes previously in BMWs I’ve owned and never seen the oil this dark. |
19th Nov 2023 1:01pm |
When you say the oil level is correct, how did you check it? TBH, unless there is evidence of a leak (or coolant in the oil) then the level should be OK - 115k is way past the accepted life of the oil. |
19th Nov 2023 1:23pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 980 |
The fault could also be downstream of the transmission e.g. output shaft spline, or maybe the transfer box or a driveshaft joint popped out?
19th Nov 2023 2:41pm |
Oil level was checked with the oil between 35 and 40 degrees. I had some zf lifeguard 6 lying around from a previous car. So drained a litre and then when at the correct temperature it took nearly 2 litres, unfortunately this made no difference. |
19th Nov 2023 3:24pm |
Was that with the engine running?
19th Nov 2023 4:17pm |
Yes engine running.
19th Nov 2023 4:50pm |
So back to the TC / flexplate then. I have seen a flexplate cracked all the way around, that was caused by the transmission being refitted without one of the alignment dowels being in place causing the TC alignment to be off-centre enough to gradually rip itself away from the crank fixings.... |
19th Nov 2023 5:34pm |
