Home > Technical (L322) > “Gearbox Fault”
JW911
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
“Gearbox Fault”
This flagged up this morning. 2012 TDV8 with 78000 miles. The knob comes up and turns fine, it just stays in Park when an alternate gear is selected, which then flashes red on the selector. No mechanical sounds or any indication of internal movement whatsoever. Fresh battery six months ago, gearbox oil changed about a year ago.
I had this six months or so ago resulting in the release cable (the one under the cup holder) being replaced. First port of call is to pull the cup holder and reset the cable.
Second is a hard reset (disconnect the battery presumably - which terminal)?
Third is RAC to trailer it to the specialist, which is where it will be going anyway if I can get it into drive.
Any other ideas please? 2012 4.4 TDV8 Westminster
2007 3.6 TDV8 Vogue - gone!
2003 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #678230 18th Nov 2023 2:08pm
Baltic Blue
Mine did it once, several years ago and I found that by switching to low ratio and back a couple of times cleared it.
It hasn’t happened again since.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #678232 18th Nov 2023 2:56pm
JW911
Thanks. I’ll give that a go. 2012 4.4 TDV8 Westminster
Post #678234 18th Nov 2023 3:11pm
Baltic Blue
https://www.fullfatrr.com/forum/topic54719...ck+park%2A
Not sure if this will help, but it is similar??
Post #678247 18th Nov 2023 8:17pm
JW911
Thanks for the link.
I used the secret fourth option in the end. Leave it for the day and go out. I tried it this evening and all is back to normal. From reading the link, I suspect it may be condensation on a contact as the garage was cold and it was relatively mild outside. So much so, the other car instantly misted up on the outside as I drove it out.
Funny as it shares the garage with the BMW, which also has the ZF8 and seems to work every time. Whistle 2012 4.4 TDV8 Westminster
Post #678253 18th Nov 2023 9:39pm
