![]() | Home > Off Topic - Other Cars > Range rover Sport 2014 4.4 V8 L494 none start issue ! |
2005aughton Member Since: 17 Nov 2023 Location: North Wales Posts: 15 ![]() ![]() ![]() |
went into history codes in air bag module and found B10-36 & B10a-32 |
In case you check back, P062D-11 will cause a non-start, check for damaged / short to ground on an injector or injector harness. Some injectors don't like mechanical shocks and can fail to ground. quick & dirty test - unplug one at a time (with ignition off!), clear DTC & try cranking, if still not firing, then check the harness with ECM unplugged for mutual short or short to ground. |
Thanks for the reply, yes I did think of this but its hard to get at the injectors that why we didn't do it but I think its worth a try especially if there is one that could be shorted to ground, thanks for the help |
Found 2 injectors had a short disconnected and injector driver fault has now gone, we still has a none start but cranks, we have no coms on the HS can bus we have found that the BCM Fuse Box when the plug is disconnected we loose the 12v feed down the HS can line to the ECM so our guesses is that we have an issue inside the Fuse Box BCM. |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Have you checked it has fuel in it? Copart like to drain the tanks for fire reasons... Worth chucking a couple of cans in it... |
yes it has fuel in it, when I put a node light on the injectors wires it has no pulse so no power going to the injectors form the ECM.
