Home > Maintenance & Mods (L322) > 019 AGM not enough power |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
It might not be the battery, I've modified several L322's L319's & L320's due to FBH not firing because of volt drop in the circuit, it's pretty simple, run a new fused supply from the +ve terminal of the battery to the power connector on the FBH. 2mm wire & a 15A fuse is ideal. |
17th Nov 2023 9:28pm |
Tomc Member Since: 15 Oct 2020 Location: Belfast Posts: 37 |
Hi phoenix, thank you for your reply. I will try this ASAP. Have you any details on the power cable and its location on the burner please.
17th Nov 2023 9:51pm |
It should be self-explanatory when you see it, there is a 2-pin connector with heavy wires and a couple of connectors with much smaller wires, one goes to the coolant pump, the other is the control wires - I think a 6 or 8 pin connector with three or four smaller wires.
17th Nov 2023 10:08pm |
Excellent, thank you . Look forward to sorting it soon. T |
17th Nov 2023 10:24pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 812 |
What length of 3mm wire do you need please for this mod? |
17th Nov 2023 11:10pm |
Sorry, I never measured it - I just used it off the spool. A metre would be more than enough, I used to replace the receptacle in the housing to reduce the number of connections but if you want to joint it to the existing then I'd recommend using a crimp connector with adhesive lined heatshrink covering not soldering. |
18th Nov 2023 7:13am |
