![]() | Home > In Car Electronics (L405) > 2016 L405 illuminated door sills |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1293 ![]() ![]() |
Use the WIKI tab (top right).
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 899 ![]() ![]() ![]() |
I’d carefully re-check if the wiring is there - I owned a ‘base’ spec Vogue in the past and that had the wiring fitted, so surprised if a 5.0 SC doesn’t, the plugs were well tucked away under the carpet / soundproofing and were not obvious initially - they should have a blanking plug in the connector which needs removing 👍 Jonathan
sconnell80 Member Since: 17 Nov 2023 Location: New York Posts: 44 ![]() ![]() ![]() |
I’ll check again today after work and try to pull up the carpet some and dig under there and the installation and see if I can find them. Not a lot of work to work and I was expecting them to be sitting right there on the floor pans. I can’t believe it wouldn’t be wired for them as it wasn’t a cheap vehicle from the factory and is a high spec RR. |
PhillV8s Member Since: 03 Jun 2022 Location: Worcestershire Posts: 45 ![]() ![]() ![]() |
I replaced mine just last week, the plugs for the front plates were under the plastic trim on the B pillar side.clipped into the floor with blanking plug fitted as already stated. 2013 SDV8 4.4 Vogue SE Aintree |
Unfortunately the plugs weren’t there when I looked. I’m hoping they are stuffed under the carpet or in the insulation somewhere. |
Well I tore everything apart and they must of forgot to put the harnesses in for the illuminated sills as I couldn’t find them. On a positive note they are now operational and took about 30mins start to finish |
