Home > Technical (L405) > Battery Replacement
Nasher
My experience is purely with my D4.
You change the battery and then 'tell' the car you've changed it.
I've always done it as I've always had a GAPII tool to do so and it takes seconds, but have often wondered if it's really neccesary.
I've seen explanations that the ECU uses the information to 'adjust' the power requirements from an older battery, which I believe to be complete B0ll0cks.
I've also heard that it's something to do with the calibration of the Stop/Start which sounds more feasible.
But as I mentioned, I've not noticed anything wrong 2yrs into the last change on my D4 without doing the ECU bit.
HOWEVER, again, that's a D4 and the L406 could be completely different.
Post #678067 16th Nov 2023 1:47pm
Gremlin500
RRV8SC wrote:
What exactly are you “coding” when fitting a new battery?
BMS reset for the new battery. Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #678070 16th Nov 2023 2:04pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
For the older stuff, at least, telling it there’s a new battery is supposed to recalibrate/reset the Battery Monitoring System to avoid overcharging etc.
Post #678072 16th Nov 2023 2:08pm
