Home > Technical (L405) > Smart key and TPMS system fault 2017 L405 |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Fuse 27 where? was the ignition on?
14th Oct 2023 4:31pm |
Chip41 Member Since: 08 May 2023 Location: Manchester Posts: 4 |
Fuse 27 in passenger side fuse box behind the glove box.
14th Oct 2023 5:46pm |
Yer, looking at the sub-circuits, it's also the supply to the RF receiver, are you sure you put the fuse back in the correct position? take the fuse out and see if there are contacts top & bottom of the position, if there is only one contact, it's in the wrong place. I can't honestly recall if the marker is above or below the fuse position, but you wouldn't be the first to get it wrong....
14th Oct 2023 6:03pm |
Well this is embarrassing...... |
16th Oct 2023 5:29pm |
16th Oct 2023 5:49pm |
Norman.D.Seagull Member Since: 20 Dec 2022 Location: Lymington, Hampshire Posts: 14 |
Just a question about the TPMS on my 2015 SDV8 autobiography - I have always rotated my tyres on previous vehicles to keep the best tread depth on the off side front which wears the quickest , largely due I am told by roundabouts!
14th Nov 2023 4:14pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35290 |
you can place any wheel at any position and it will 'read' the pressure...it normally takes around 15 miles to re-calibrate. ... - .- -.
14th Nov 2023 4:18pm |
Many thanks - that makes life a lot easier! Would a brand new TPMS unit need to be programmed in or is it automatic ? |
14th Nov 2023 4:25pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
Nope, no coding needed, as Stan says just takes a while to be read... Pete
14th Nov 2023 4:36pm |
Offside front? most tyre wear is nearside front, unless you're in the habit of 'enthusiastically' pulling out of junctions when turning right...
14th Nov 2023 6:06pm |
Thanks for that - My dyslexia playing is up !
15th Nov 2023 2:12pm |
