Home > Photos, Videos & Media > Think I’ll stick with my L322.
PeteT80
Post #677854 13th Nov 2023 3:36pm
mjdronfield
Nice video. Something has got to be done. Those figures are scary.
Might be a good job I’ve never been in an L405 yet….
Next door have a fairly new all black RRS that’s parked outside. He is getting panicky….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #677858 13th Nov 2023 4:11pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Post 2018 cars have UWB keys - they aren’t being stolen by relay attacks.
Post #677861 13th Nov 2023 5:01pm
disable keyless entry and that 'relay' problem is also solved... ... - .- -.
Post #677863 13th Nov 2023 5:21pm
Phoenix
Disable 'keyless' entry (an Oxymoron!)
Fit something like Meta Nemesis
Fit a electrical switch disconnecting something that cannot be overridden by 'emergency starting' hacks.
Sure, it won't bring your insurance down but maybe the scrotes will walk on by once their initial attempts fail.
Post #677867 13th Nov 2023 5:51pm
JDGeorgia
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
I wonder if I could hop a Big Delta Jet to Heathrow and set up a Pop-up shop fitting folks with a $5 Amazon switch and 4 meters of wire... I have done it enough that I can fully disassemble an L405 console in 30 mins or so. Run the switch to a place of their choice - close up the console/dash and collect my £500. Seems like there is a Knighthood somewhere in there. Cool
Crack the console...
Clip the Brown/Red wire and solder in a switch for the VBatt - Pin 1
Run that switch to a hiding place of your choice - behind the valet mode/upper glovebox seems like a natural choice (Downside of that is waiting for the screen to come up so you can enter the valet code to get in the upper glovebox) - but get creative..
"Scrotes" are looking for path of least resistance - make your L405 the more Puritanical (least 'easy') on the block... The old saying goes - I don't have to be faster than the Bear - I just have to be faster than YOU! 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Rolled Yahtzee Aug 2023 222,222Miles
2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel'
Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted!
97K at purchase Sept of 2023
Post #680508 16th Dec 2023 11:22pm
JDGeorgia
Tell your neighbor to crack open his console... here is what his L494 wiring harness looks like...
Clip Pin 10 Brown/Red and splice in a switch. Splice in enough wire to hide the switch wherever he likes...
In the cubby... under the dash... in the glove box behind the valet function... hell he could route it to the 'boot' if he was feeling froggy - impractical, but 'scrotes' would never find that!
Here is what an L494 lever looks like in an L405...
I can neither confirm nor deny that I spliced-in during this conversion... Thumbs Up
We have this little 2A thing that helps crack down on Scrote... um... activity... I highly recommend it! 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Post #680509 16th Dec 2023 11:34pm
