Home > Technical (L322) > Do (2008) 3.6's suffer from spline wear in the drive train ? |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
Yes, spline wear on the gearbox o/p shaft and the transfer case input shaft is a known issue and will eventually strip both shafts. They're assembled with a special grease but either the quantity of grease applied at assembly is sometimes inadequate or on some the grease dries more quickly than on others.
11th Nov 2023 7:53pm |
Dutchgit Member Since: 17 Sep 2023 Location: Emmerich am Rhein Posts: 178 |
Oh balls ! Not looking forward to removing the t-box. Not looking forward to fixing the problem either ! |
11th Nov 2023 8:52pm |
Obviously you need to eliminate all other possibilities first. |
11th Nov 2023 9:14pm |
Yes I need to spend some time under the thing anyway. I discovered a small oil drip where the rear of the lower front a-arm is attached to the engine cradle thing and I need to change the oils as well. |
12th Nov 2023 3:36pm |
