Home > In Car Electronics (L405) > HUD _ Heads Up Display Internal Pics/Fan Part #'s
JDGeorgia
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
The heads Up Display in my MY16 L405 TD6 will run for about an hour and then seems to overheat and shut down. This is a recent problem in the past 2 weeks. I bought a unit off eBay for a 2017 and plan on replacing the '16 unit with that. Prior to any of this - I am going to source and replace the fans on the 2017 unit. Tore into it tonight and have some pics to share.
This is obviously a composite - let me know if you need more
There appear to be 2 projectors - possibly 1 for the Speedo and Cruise and 1 for the Nav? Both Projectors have a fan.
The 'Main projector' has a Delta Electronics Model ASB0412MA - 3 wire
https://a.co/d/daAv9xa
The Secondary Projector - maybe just the Nav Info - because it is smaller so less used? Also has a fan - but smaller. The small fan is also a Delta - Model ASB0312LA.
https://a.co/d/6fCSNde - This one has 4 wires - they also make 2 wire...
The Range Rover has 3?
https://www.digikey.com/en/products/detail...00/3444174
The light appears to move as shown
There is a spinning diffuser right before the Fixed Concave Primary Mirror.
The secondary and Final Concave mirror is attached to a motor to adjust up and down...
Let me know if you have a specific pic you need - I can tear it back down 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Rolled Yahtzee Aug 2023 222,222Miles
2016 L405 HSE TD6. Santorini Black over Almond. - 'Donna the Diesel'
Only L405 IN THE KNOWN UNIVERSE with an L494 Shift Lever Fitted!
97K at purchase Sept of 2023
Post #677637 10th Nov 2023 1:22am
fisha
Your secondary projector as you call it, may actually be a DMD from a DLP projector setup … Laughing
In other words … your primary projector is just a light source sending light out, and rather than passing it through an LCD screen to control pixel brightness, it’s bouncing that light off an array of very small mirrors ( your secondary projector bit ). The mirrors are controlled at a pixel resolution to bounce the light either onwards to output end of the display to light up a pixel, or somewhere else to no light up a pixel. ( possibly that somewhere else is behind the mirror array which is why it needs a heat sink to dissipate the light energy its not sending onwards ). V8 or else ...
Post #677696 11th Nov 2023 12:52am
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
The HUD is manufactured by Panasonic, as are the Touch Pro Duo screens:
Post #677698 11th Nov 2023 5:48am
JDGeorgia
Not being an LCD expert - nor do I play one on TV... Turning this into a printer analogy -
My 'Primary Projector' is the ink cartridge, and the mis-named secondary projector is the inkjet printer head. It bounces light on or lets it through to form the characters I see 4 or 5 mirrors/diffusers later...
I am not looking forward to that swap... the workshop manual makes it look like a pretty thorough tear down. 2006 L322 HSE LUX 4.4NA Jag V8 Buckingham Blue/Ivory - 'Col Reb'
Post #678113 16th Nov 2023 9:35pm
