Home > Technical (L405) > Weird tailgate issues
DamianK
Hi,
I have just had the battery replaced and I am not sure if this is related to this issue or just a coincidence.
The rear tailgate, when the button on the remote or in the car, raises to about three quarters height then stops and beeps. If I press the button again it will carry on and fully open. When I go to close it it will close but looks like it is not flush and if I press the lock button the car bleeps twice but doesn't lock and if I look at the dash, it's telling me the boot is open.
If I manually close the boot then the car will lock, I have looked to see if there are any obstructions and I cannot see any. It was working fine before the battery change.
Post #677667 10th Nov 2023 3:35pm
Alignment ?
https://www.fullfatrr.com/forum/topic65356.html
Post #677669 10th Nov 2023 4:07pm
Arch Stanton
Re: Weird tailgate issues
Unnecessary quote removed
I had something very similar after an oil change service at my local dealer, it wouldn't comply with the reset position procedure. I tried all sorts and it wasn't playing. Reported it to the dealers to go back and fix but then after a long journey it sorted itself out, never to return. Onto my 2nd FFRR, this time an L405 5.0L SC AB in SVO Palette black.
Post #677682 10th Nov 2023 7:40pm
Gremlin500
Hi DamianK,
As advised by Phoenix on another thread tonight:-
“ Manually fully close and open the tailgate & the liftgate, with the lift gate in its fully open position, press and hold the close button until you hear a couple of chirps, that should reset the extents and all will work as expected.”
Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #677695 11th Nov 2023 1:10am
philbathurst
United Kingdom 2016 Range Rover Vogue SE TDV6 Montalcino Red
DamianK
I also changed my battery last weekend and had exactly the same problem with the tailgate, and the problem is that if the car thinks its not closed you are unable to lock it
I tried all the reset procedures with no success
It turned out my problem was that one of the trim panels on the lower tailgate that have the anti pinch sensors built into them was not fitted properly, I removed them both and refitted them, problem solved
hope this helps various other LR's this one is still the best
Post #677697 11th Nov 2023 3:17am
