Home > Technical (L322) > Irritating, really irritating! |
Floopy Member Since: 28 Jan 2023 Location: Chichester Posts: 81 |
Sorry to hear about your missfortune, I had my door cable snap last week but fortunately the repair went well.
7th Nov 2023 9:42am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7801 |
Isn’t there a way to open the front door by accessing the latch when the rear door is open? Seem to remember something……
7th Nov 2023 9:57am |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1477 |
Not sure if this thread will help at all?
7th Nov 2023 11:52am |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 541 |
Thanks for the comments guys. Everything appears to work as it should, the locking actuator responds to the key fob and the plipper thing on the top of the door card goes up and down with locking and unlocking, the problem is it clearly isn't actually unlocking the latch which is why neither internal or external door pull works. I must have dislodged something when I was having my fight with the door card to get it back on. I shall be out there soon! Drives:
7th Nov 2023 12:52pm |
Well, at least I now know what the problem is. The door has deadlocked and then it's jammed, apparently it can happen. I've looked at various Youtube videos and they're no real help other than the confirm the issue, the videos are so wobbly and out of focus at the crucial time you can't see exactly what needs doing. This is going to the garage, I'm out! Drives:
8th Nov 2023 8:16am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1468 |
Sounds like you didn't hook and click the plastic connector back properly to the interior door handle. It can look like it's connected but actually isn't.
8th Nov 2023 9:54am |
Gary, I don't think I've explained it very well. The cable is correctly installed and was working perfectly (still does, I can see both internal and external cables operating correctly when pulling the door card back enough to see. What has happened is that when I locked the car the drivers door deadlock has jammed in the locked position. The central locking actuator still works correctly and the pin pops up and down as it should, it's just that the deadlock won't disengage. Drives:
8th Nov 2023 12:23pm |
Any help?
8th Nov 2023 12:46pm |
Thanks Floopy, I have seen that and a couple of other videos. The problem is identifying the bit to trip when it's in the car. I think I may need to get hold of a locking mechanism so that I can see it in the flesh for myself. I haven't given up, but I think it will be a garage job in the end, but who knows?
9th Nov 2023 8:29am |
What about the “remove & replace Fuse 24” thing at the end of the thread I mentioned above? Is that just t’Interweb BS? (OTOH, If it’s something mechanical you have fiddled with, I can’t see a fuse helping….)
9th Nov 2023 8:45am |
This is the really annoying thing Gremlin, I didn't fiddle with it at all, simply hooked the end of the bowden cable in place and clipped it in, nothing moved which is why I don't know what's caused the deadlock to jam. Not only can I hear the main lock actuator operating, I can hear the deadlock mechanism as well (makes the same noise on every door), it just won't release the drivers door. Drives:
9th Nov 2023 12:41pm |
Have you tried using the key in the manual lock hole under the handle cover? 2006 L322 Vogue SE 4.2 |
9th Nov 2023 12:46pm |
Mines on the passenger side, so I don't think that will do much sadly. Drives:
9th Nov 2023 3:16pm |
Here's some info for anyone who has this happen to them.
10th Nov 2023 4:30pm |
