Home > In Car Electronics (L405) > Update (sort of) for my USB woes in 2017 AB |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
The battery might not have a low enough terminal voltage for that but the SoC may be low enough to cause the infotainment to reinitialise after cranking due to a voltage dip when the starter is operated. |
8th Nov 2023 6:46pm |
DamianK Member Since: 04 Aug 2023 Location: West Sussex Posts: 58 |
Do you mean in reference to the usb in the central console never recognising my iPhone after the car has sat overnight? I am hoping it is the battery but then am not massively confident either. It’s weird, I have to try and lock the car leave it for 5 mins and then restart and then it may see the iphone (not every time but about 60%). |
8th Nov 2023 7:47pm |
Had the battery changed this morning and. so far, the USB's and Car Play working as it should - but the real test will be tomorrow morning (will report back then) but since doing the battery change another issue has arisen *sigh*
10th Nov 2023 2:37pm |
Manually fully close and open the tailgate & the liftgate, with the lift gate in its fully open position, press and hold the close button until you hear a couple of chirps, that should reset the extents and all will work as expected. |
10th Nov 2023 3:11pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1558 |
Aha!
10th Nov 2023 11:59pm |
Quick Update - the battery change did not fix the issue so back to the dealer it went and they have just informed me they now think it needs a new INFOTAINMENT CONTROL MODULE at a cost of ÂŁ1877!!!!
15th Nov 2023 11:06am |
So with experimenting I have found that if I turn the car on and then immediately turn it off, wait about a min and then start up the Apple car play works. Weirdly if I have an update USB with a map update and plug that in it see’s that and does the update no issue, even if the car has been sat overnight! So the USB are read just seems not for Apple Car Play! |
27th Nov 2023 1:25pm |
