![]() | Home > Technical (L460) > Keyfobs and profiles |
Convenience mode is what you're describing, for some reason it seems to not be active on your vehicle - go back to the dealer with this page from the user manual https://www.ownerinfo.landrover.com/docume...3/G2735851 |
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 443 ![]() ![]() |
Thanks Phoenix, will try that! |
Just an update on this one: Have been in contact with the dealer several times, and the issue have been reported. Still not working. Main profile doesn't stay logged in to InControl, and when pairing a keyfob (by having one of the keybob inside the car) with one of the 2 profiles and storing the seat&steering wheel position with Mem+1, the vehicle is still not able to remember the Profile+keyfob+seat position settings.
Eisbärhöhle Member Since: 21 Mar 2022 Location: Germany Posts: 26 ![]() ![]() |
@Eirik34 ...
Thanks Eisbärhöhle! I just hope it is a software bug on the MY24, but the dealer hasn't got any info from JLR about such a bug.
@Eisbärhöhle: In your vehicle, are you able to connect a keyfob to a PiviPro profile so that the driver seat and steering wheel automatically are adjusted before you enter the vehicle?
Hi Eirik!
Hi Eisbärhöhle, yes - according to LR the convenience mode should work in the MY24:
Hi Eirik ...
HalfMinuteMile Member Since: 18 May 2024 Location: Silverstone Posts: 16 ![]() ![]() ![]() |
Hi, I just received my new RR and for the life of me can’t seem to see how to assign profiles to each key. Do I need to set up 2 accounts on InControl? |
According to our dealer the convenience mode doesn't work anymore. Not possible to assign a keyfob to one of the profiles in PiviPro, so now one has to hold the memory button in the door panel before entering the car to adjust the seats etc. Disappointing!
Oh, right, that’s disappointing! Something other brands have been able to do for the last 20 years…
noone Member Since: 05 Apr 2025 Location: Florida Posts: 4 ![]() ![]() |
Is this true that the L460 is not capable of having two driver seat, mirror and steering wheel position profiles, 1 for each key? I can't figure this out either! 2023 RR P400e |
Still the case, unfortunately. You can store seat and steering wheel positions and use the memory buttons in the door panel before you enter the car. But these are not linked to the key-fobs.
