Home > Technical (L322) > Emergency key slot missing |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 |
Hi
4th Nov 2023 3:38pm |
Murakami Member Since: 08 Sep 2023 Location: Dublin Posts: 10 |
No offence taken, I appreciate the reply.
4th Nov 2023 4:09pm |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 |
Has it had new door handle covers slotted over the original handle, like powerful uk sell? |
4th Nov 2023 5:11pm |
Good idea. But they really don’t seem to. I did pull the handle and check it out from the side and it’d didn’t seem to have a double layer, if you know what I mean. |
4th Nov 2023 5:19pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Have you checked the other side? |
4th Nov 2023 6:55pm |
I did indeed. |
4th Nov 2023 7:02pm |
Are you able to get under the front of the car and attach a charger to the +ve stud of the starter motor & the ground to the engine? - easiest done with the OSF wheel off but I guess your locking wheel bolt key is in the car...
4th Nov 2023 7:29pm |
Having had a quick search there are some quite cheap replacement door handle parts if you need to sacrifice the one you have. Do you have towing electrics as that can be another potential route for getting some charge into the battery. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
4th Nov 2023 7:45pm |
Thanks for all the input.
5th Nov 2023 3:47pm |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 194 |
If you have to change your battery then remove the pollen filter assembly first and use some steps to gain a little height. You will find the details on here on how to gain plenty of room and safety dis connect the battery etc. Doing this makes it all straightforward.
6th Nov 2023 9:21am |
6th Nov 2023 5:21pm |
So I picked up the Yusa battery recommended by Halfords and went off to replace the dud.
7th Nov 2023 11:23pm |
I'm just going to do a quick update on this, as someone may or may not be interested. Ladn Rover dealer here in Dublin didn't want to talk to me when I presented them with the issue. They were relatively polite, but still feel showing up in my work clothes wasn't the best idea.
12th Nov 2023 10:09am |
Conclusion for anyone interested.
16th Feb 2024 5:34am |
