Home > Technical (L405) > Obstacle Detection Module fault |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Usually caused by low voltage to the rear RADAR sensors, this can be during cranking if the starter battery is depleted, ideally you'd need to know the frequency of the DTC being set to determine if it's a recurrent fault or sporadic/one-off, if it's recurrent, then it'd be worth checking the connectors on the units behind the rear bumper for water ingress & corrosion.
4th Nov 2023 5:42pm |
Dtac122 Member Since: 15 Dec 2022 Location: Norfolk Posts: 6 |
Thanks for that. I have just found out that as I don’t have the rear radar fitted to my vehicle. There is a recent Land Rover bulletin which states in that event the codes can be ignored!!! |
4th Nov 2023 5:48pm |
