![]() | Home > Technical (L322) > PDC Error |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Now and then when I reverse out of my garage the PDC system instead of bleeping front and back as it should just has a continous high pitch beep (the same tone as the front sensors).
Are you certain there is nothing on the sensors? You haven't blasted them with a jetwash or anything recently? Checked for small children stuck to the bumper?
Not long after I originally bought the car 2 years ago I found the PDC to be unpredictable and would often just beep away at nothing. As it was under warranty the dealer had it in 2 times but said there were no faults logged and they even dismantled it all, nothing bad found.
tdv8king Member Since: 07 Aug 2009 Location: loughton Posts: 3 ![]() ![]() |
simple way to start diagnosing a pdc fault have a listen to the sensors. with the rr in reverse and put your ear close to each sensor you should be able to here a quite dit dit dit dit dit. when checking the sensors also check for a surdace damge to the head like scrapes or scuffs and if there is any paint lift on sensor. if a sensor is quite and not making any noise then remove the bumper and first inspect the bumper loom for damge or corrosion. if ok at this point i would say the sensor that was not doing the dit dit dit is at fault and would require replacing.
Full fat not diet Member Since: 16 Nov 2008 Location: Herts Posts: 1209 ![]() ![]() ![]() |
Love the "dit dit dit dit dit" sound efects |
This fault stopped occurring not long afterwards, weird, it just went away and its normal ever since. |
