![]() | Home > Maintenance & Mods (L322) > Rear light clusters getting condensation inside the perspex |
remove the light (very easy to do just 2 hex bolts inside the tailgate).
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2562 ![]() ![]() ![]() |
Seal the join where the clear meets the backing if the join has come adrift as mine did. |
Proftinkerpot Member Since: 22 Dec 2022 Location: County Antrim Posts: 187 ![]() ![]() ![]() |
Thanks for the comments. It sounds like the same issue I had with an F30 335d BMW. One of the rear clusters had this issue and I used to remove it and set it on top of a dehumidifier for a couple of hours and then refit it. |
Yes, a night in the airing cupboard used to sort mine out on the occasions it happened... It seamed weather would start it off, the more water got in, the more it would attract! Very odd UK weather... |
It's reassuring to know that it isn't just me having the problem Craig. |
No no, a very common problem sir... Just been splitting apart a set of DB9 rear lights to re seal them as Aston Martin chose to seal them with something that resembles nylon! Weird... |
You would think Aston could come up with a slightly more suitable product to use as a sealing product Craig.
Baffles me sir... |
