Home > Technical (L322) > Normal to top up coolant after work on cooling system? |
JCM24 Member Since: 03 Jun 2023 Location: Dordogne Posts: 7 |
Hello Phil, nothing unusual for me.
1st Nov 2023 12:30pm |
Rackers Member Since: 04 Apr 2022 Location: Portsmouth Posts: 74 |
Definitely normal but it should eventually stabilise and not continue to drop. |
1st Nov 2023 1:05pm |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 523 |
Thank you gents.
1st Nov 2023 2:02pm |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 584 |
I can feel your frustration with the garage. I have very bad experience myself, being a rip off and poor workmanship victim in the past. As a result now, I demand any work on the cooling system and the eventual system bleeding to be carried out in my presence, including a pressure test. With that said, If I can do the job myself, I just do it and have peace of mind. On your coolant top-up question, yes, it is very normal having to add some coolant, even after having bled the system to the best of your ability. As mentioned by others though, the level should stabilize at some point, say after a couple driving cycles. |
8th Nov 2023 1:15pm |
Thanks. It seems to have settled now, not topped it up after the last 2 drives which were an hour or so long, so hopefully thats one issue fixed.
8th Nov 2023 4:24pm |
should be fine now.
8th Nov 2023 5:05pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Glad its sorted sir... Till the next thing |
8th Nov 2023 11:43pm |
