Home > Technical (L322) > l 322 air suspension |
Discofish Member Since: 21 Jul 2020 Location: Nottingham Posts: 104 |
i'm having a very similar issue with mine and to answer your question from my investigations your assumptions are correct but i understood the supply was 5 volts not 12.
30th Oct 2023 5:00pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
"and they stay up over 2 days no problem"
30th Oct 2023 5:24pm |
rover75lover Member Since: 02 Aug 2021 Location: wales Posts: 13 |
many thanks for the reply ,it stays on high if and only if i use the rsw softeare to "depressurise " ,the backs lower and the front rise . I then stop the software and it will sit on high no problem. There are no fault codes logged but the high led remains on even if i depressurise it all around .
30th Oct 2023 8:36pm |
I think the 6 pins are if you have xenon headlights and the headlight ecu uses the other pins . If the ecu headlight is faulty the air suspension wont work . Thats what one educated l 322 professor told me so its not from peRsonal expeRience . If i EVER crack this walnut ill be back on straight away . Ive done loads on it new compressor new rear height sensors ,overhauled resealed the valve block ,swapped the ecu from my good l 322 and this one still performs the same and my "good suspension" l 322 works fine with my bad suspension l 322 ecu installed . I dont get any faults recorded with the rsw code reader so im beginning to scrape the barrel Ive checked the ecu to valve wiring ,all good . Really scrapping the barrel now |
30th Oct 2023 8:43pm |
Typical... just to make it more complicated they have to bring headlights into the mix
31st Oct 2023 8:57am |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 386 |
Sounds a bit like we are both in the same boat ……I’ve got suspension ecu issues as well (won’t calibrate) and suspension dropping still not got any fixes from here yet |
31st Oct 2023 10:27pm |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
Has the arm been flipped the wrong way round? the six-pin sensors can be used in place of the three pin ones, they're two separate units in one housing. |
31st Oct 2023 10:47pm |
when it left the MOT place it was flipped unbeknown to me however when it was put right the front pumped up beyond off road and burst both front bags and its not worked since reliably.
1st Nov 2023 8:01am |
hi
15th Nov 2023 1:15pm |
that's the one (although a bit tight for space if i remember when i looked at mine) |
16th Nov 2023 9:11am |
I've got an issue with mine so got a second hand one which im going to flash it with the gap tool and hoping that sorts out my problem |
16th Nov 2023 12:45pm |
