Home > Technical (L322) > Nobody knows what is going on with my 4.4 TDV8 2011... |
Yorch1 Member Since: 29 Oct 2023 Location: Deeping St James Posts: 12 |
Fellas, I am officially depressed.
29th Oct 2023 7:20pm |
In the video the engine is not switching off. The engine is on all the time! |
29th Oct 2023 8:54pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2385 |
It sounded to me as though it was restarted several times. |
30th Oct 2023 8:15am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3051 |
Pull off the connector to the intake just infront of the throttle and check the throttle plate is not loose as the control mechanism can sometimes break due to carbon build-up from the EGR system. 2012 TDV8 Vogue (L322) |
30th Oct 2023 8:44am |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 265 |
@Yorch1; there seems to be three repeats of the same issue in the recording, correct ? It might be clearer to show a single instance. TDV8 4.4 2012 |
30th Oct 2023 8:45am |
The engine is on all the time. The sound is the engine trying to get air |
30th Oct 2023 10:27am |
It appears that the video is on permanent repeat. I stopped it after it started replaying the same video for the 6th time. Hence the restarting isn't indicative of the issue.
30th Oct 2023 11:17am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
I agree with both GraemeS and Jaygee as to possibilities.
30th Oct 2023 11:23am |
GraemeS, the EGR was blanked one year ago and the car was remapped.
30th Oct 2023 11:24am |
A how to from the WIKI here shows the TB removl and precautions.
30th Oct 2023 11:27am |
If the main valve that you refer to is the EGR throttle butterfly then that's another reason to check the butterfly for looseness. |
30th Oct 2023 11:30am |
How long after this did the fault start to happen. 2012 TDV8 Vogue (L322) |
30th Oct 2023 11:37am |
2 or 3 months |
30th Oct 2023 2:32pm |
Do you mean the big butterfly at front of the plenum? That butterfly is the one clicking (open-close-open-close...) meanwhile the car is performing the fault! |
30th Oct 2023 2:49pm |
