Home > Technical (L322) > Intermittent non crank starter issue TDV8 4.4
QuebecTango
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
I know this has been covered before, but I have been suffering this inconvenience. Have spent some time this afternoon investigating battery voltage, earth and exciter wire to the starter. Checked for voltage drop on these when the dreaded “click” occurs. Of course it was reluctant to fault ! The exciter lead from engine fuse box to starter solonoid appears to be the issue : when starting normally there is a drop of 0.70V which I would consider to be high. When fault manifests the drop is 2.75V, battery voltage at around 12.1V . Measuring resistance of the open circuit wire does not show an issue - no load.
Next step run a new wire in a see where we go. Any one got any more thoughts
Cheers
Q
Post #676729 28th Oct 2023 5:38pm
garyRR
Could be along the right lines. The cables were poor quality and suffer degradation. As cabling is cheap, a good place to start / a good bit of preventative maintenance to do regardless.
Not had an issue on my RR, however I had a simar fault on my boat. The voltage was dropping c.2.5V to the starter. Tested the cable and the resistance was quite high. Replaced with a new and proper marine tinned cable and normal service resumed. 2015 Range Rover Autobiography 4.4 SDV8
Post #676748 29th Oct 2023 8:41am
DrRob
I’d love a how to guide to replacing these dodgy cables Gary Whistle Bow down Very Happy Wink Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #676770 29th Oct 2023 12:49pm
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Is this the main high current wire to the motor or the smaller wire to the solenoid?
Thanks.
Post #676830 30th Oct 2023 10:31am
QuebecTango
The smaller wire to the solenoid
Post #676947 31st Oct 2023 8:11pm
Mike Edwards
Thanks.
Post #676952 31st Oct 2023 9:02pm
