Home > Maintenance & Mods (L405) > supercharger - 5.0L - L405
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Right Guys
I was ask by my Copilot - does the
L405 5.0L Supercharger have its on Oil supply ?
OR
is it feed from the Engine Oil ?
I have no idea
Something I am sure feeds this mighty animal .....
Who knows this one ??
Post #676247 23rd Oct 2023 6:16pm
It has it's own oil... Thumbs Up Pete
Post #676262 23rd Oct 2023 7:53pm
EmiratesA380
Hi Pete
You say it has its own - where is it then ?
Can you up load a picture of fill drain ?
how much oil goes in it then ?
Thanks
Post #676270 23rd Oct 2023 8:52pm
dhallworth
It takes around 250ml of oil and it’s contained within the supercharger gear casing.
It’s very difficult to photograph as it’s on the back of the charger and the fill plug faces the bulkhead.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #676274 23rd Oct 2023 10:09pm
More info here.....
https://powerhouse.uk/supercharger-rebuild...d-service/ Pete
Post #676289 24th Oct 2023 9:17am
EmiratesA380
Hi Pete
many thanks for posting back
I went direct to my main man at LR head office - and he knows all this stuff
sent me this today
https://www.fullfatrr.com/gallery/albums/u...0copy2.jpg
From what he told me on the phobe afterwards - is THEIRS NO OIL
on the L405 5.0L supercharger
AS it reads the Supercharger is a Roots blower
Supercharger is supported in beraings in the front cover - as the Jaguar Landrover Technical workshop
So whats all this
thoughts on this ?
Thank you in advance Fella's
Post #676369 24th Oct 2023 9:14pm
EmiratesA380
https://www.fullfatrr.com/gallery/albums/u...b_1010.jpg
whys it so dam small - the Jpeg says its 25Mb and A5 size ?
Post #676370 24th Oct 2023 9:19pm
Mikey
He knows nothing. Doesn't work in a main dealer, does he? Laughing
The 'charger has its own small oil supply within the housing
Not easy to replace, but JLR state "sealed for life" so no service interval on it
Post #676389 25th Oct 2023 7:06am
EmiratesA380
Mikey
Is that Jpeg I attached on here big ? - can you see it
when I click on it it very small
I am not sure why
Can you clearly read it
thanks
Post #676396 25th Oct 2023 9:34am
dingg1
No one can read it, your man is an eejit 🙄
Post #676398 25th Oct 2023 9:55am
Mikey
Post #676403 25th Oct 2023 11:12am
Mikey
https://www.fullfatrr.com/gallery/albums/u...0%20sc.pdf
Quote:
The two rotors of the SC are contained in a housing. The ends of the rotors are supported in bearings in the front cover and
the bearing plate. A rear cover seals the bearing plate and incorporates a filler/level plug for lubricant.
Post #676404 25th Oct 2023 11:34am
As others have said it defo has oil, changing it is one of those preventative maintenance items, like the claimed "Sealed for life" gearboxes some time ago...
I think they say it to reduce servicing costs and they know that it will be fine till out of warranty and that's all they care about....
This is where you need a good indy who knows the vehicles.... Thumbs Up Pete
Post #676406 25th Oct 2023 11:54am
EmiratesA380
after landing at BHX I wanted to drive and see my friends at Gaydon Jaguar Landrover according to them the Supercharger is a Roots Blower - and hther's NO oil top up at all
The older Superchargers used to have a unit
The Supercharger uses x2 large sealed bearings front and back - sealed for life.
also the Roots blower has high angle helix rotors which are driven at 2.1 times engine speed by the secondary belt of the main accessory drive belt.
found this link while away and thought I would share it
https://www.jaginfo.org/threads/5-0-v8-aj1...y_top_post
hope this helps others
Post #676910 31st Oct 2023 11:27am
dhallworth
Your friends are partially right… you don’t top the oil in the supercharger up…
You can however change it. There’s a fill plug on the back of the blower that you can remove. You then suck the oil out with a syringe and some tube and then refill it.
If the charger is off the car you stand it on its end and drain it out.
I’d suggest you speak to someone who knows more than your friends at Gaydon. Powerhouse Automotive in Chesterfield are the oracle of knowledge on the JLR superchargers.
I’ve just had the charger off my 5.0 and I can 100% confirm that there is oil in it accessed via the fill plug at the back. I don’t have any photos though unfortunately. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #676916 31st Oct 2023 12:18pm
