Home > Maintenance & Mods (L405) > New truck - and now a new SCR Catalytic Converter. 2016 TD6 |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
That's not how SCR works - the NOx sensors are not active until after the engine has been running for 20mins, so if there has been lots of short journeys, when there is a long one, the average usage will be exceeded and set an emissions related DTC. I'd be wary of a 'cleaned' NOx sensor, especially the downstream one as the sensing element does age and not react as quickly as it should, leading to 'SCR efficiency' DTC's.
18th Oct 2023 8:22pm |
JDGeorgia Member Since: 11 Oct 2023 Location: Atlanta GA Posts: 158 |
This is great info - thank you!
19th Oct 2023 6:13pm |
The dosing valve is a fairly precise item - or should be, it's a fast acting solenoid valve behind an engineered venturi. There are three tests - leakage, spray pattern & dosing amount over a specific time period - usually 26-31ml over 60 seconds, anything else, even just 1ml either side is a 'fail'.
19th Oct 2023 6:32pm |
I have been watching a bunch of videos by O'Rileys (https://www.youtube.com/@ORileysAutos) Auto in Biggleswade... Love the accent, but is that a real place or something from The Hobbit?!?!? at this point, I think y'all are making most of this up as you go... I know, I know... Biggleswade is probably older than my entire country, but still...
19th Oct 2023 11:36pm |
The DEF level has to be electronically sensed so the usage level can be monitored (leaks, excessive usage etc.)and low level warnings / no-start countdown will work, beware of 'brimming' the tank as this can lead to problems, especially in cold weather.
20th Oct 2023 6:22am |
I do... But where's the fun in that?
1st Nov 2023 4:45am |
