Home > Maintenance & Mods (L322) > Is there a place thats hows all clips etc?
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
I am after a clip that holds one of the coolant pipes in place, but couldnt see anything about clips of any sort on LRCat.
Is there a place to search for clips etc?
Cheers
Post #675910 19th Oct 2023 6:57pm
Phoenix
They usually come with the hoses - what diameter hose is it for?
Post #675912 19th Oct 2023 7:15pm
philip1972
Its an odd one!
Its like a plastic half circle that you just slide the hose into to stop it dropping into the fan blades (it crosses the top front of the engine.
I shall try to get a pic in the light tomorrow.
Post #675916 19th Oct 2023 7:28pm
Phoenix
Ah, right - a 'support' - like the one on 18472?
They come with the hoses too.
Post #675919 19th Oct 2023 7:39pm
philip1972
Thank you, although I am not sure they are right ones?
Hopefully some pics should be below! They clip into a metal bracket then you clip the pipe in.
First photo show one that is OK and the second shows the missing one and where it should fix to the metal plate.
Its a 4.2 SC by the way.
Post #675941 20th Oct 2023 8:19am
Phoenix
It wasn't meant to be - that was just to confirm (or not) what you were after, it's not even for your vehicle Wink
The part you want is PEK500120 (item 8772 from https://new.lrcat.com/#!/12119/94841/95970/7631/96095 ) the damaged hose is part of a set unfortunately.
Post #675945 20th Oct 2023 9:24am
philip1972
You are a superstar, thank you Thumbs Up
Post #675947 20th Oct 2023 9:38am
Phoenix
No worries, I tend to use our parts catalogues a lot so the parts monkeys don't have an excuse for ordering the wrong part - it gives an insight into the kind of sick mind needed to decide which page to put parts on....
Post #675948 20th Oct 2023 9:41am
