![]() | Home > Technical (L322) > Help please - engine cut out today |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
Monitor engine RPM with a diagnostic tool while idling or trying to start it as the symptoms suggest a failing crankshaft position sensor which won't produce any fault codes. RPM should not be zero at any time the engine is turning so if RPM drops to zero even just momentarily then replace the sensor.
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 335 ![]() ![]() ![]() |
LTB01083
AJ Johnny Member Since: 30 Sep 2017 Location: Bedfordshire Posts: 77 ![]() ![]() |
The failing sensor sounds plausible. Hopefully it will get me home. I’ll get it changed and get the fuel rail connection checked at the sametime next week.
Good suggestion. However, it has missed when doing 60 or 70 and I don’t recall seeing the flashing D or terrain response changing. It was doing 50 when the engine stopped this time. If it happens again I’ll take a close note of the dash display.
Thinking back to yesterday the engine stopped a few seconds after starting yesterday, I thought it odd but no more of it.
I wouldn't change the crankshaft position sensor without evidence that it is failing, which if the faultering is at idle would be easily determined if you have a diagnostic tool such as the IIDtool that can show live values. |
Hi Graeme,
