Home > Off Topic > Wireless cctv cameras
Andy B
@bean19844 - Image from Blink
 SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #618854 5th Jan 2022 1:15pm
DrRob
Caesium wrote:
I have been installing CCTV and intruder alarms for more than 20 years and I’d never recommend wireless cameras for anything more than a visual deterrent.
Get a decent set of cameras with a wired NVR and then you won’t have to pay subscription until the end of time. Cloud cameras are ok but locally backed up is better in my opinion.
The cameras are powered down the same cable that the signal is sent along so just one cable is needed. No climbing ladders to change batteries etc.
Wireless alarms are ok but I’d steer clear of wireless surveillance
Thread resurrection Bow down
Christian - could you point me to a system that I can install easily by diy that is mains powered via a 13pin plug and will allow me to record continuously. I assume it will have to have some sort of storage box for the digital recordings? I don’t need cloud storage but it would be great to access the footage via an App. The camera and box will be in house wifi range. I don’t want to drill any holes through house wall to connect an Ethernet cable to the box either. I don’t want to pay anyone for cloud storage as well.
Appreciate your advice Thumbs Up Bow down
Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #675757 17th Oct 2023 7:29pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Hey Rob,
All credible cameras need a wire of some sort so running an Ethernet cable is infinitely easier than a mains cable, so you’re definitely going to need to drill a hole somewhere to get the cable to the camera.
All cameras I work with are power over Ethernet so the NVR can power them, meaning just one mains power connection and no accidental powering down of mains fed cameras when they’re plugged into a bedroom socket on an extension lead - for example.
I just can’t recommend any wireless cameras as I’ve had so much bother with them from a service perspective so anything I could point you to would have to be wired, sorry dude. Christian.
Current Cars
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #675770 17th Oct 2023 9:31pm
DrRob
I may have confused things. Usually do Rolling with laughter
I can drill a hole from the outside into the garage (for powered ethernet cable). The garage has 13pin sockets for power.
I didn't want to drill a second hole from garage into the lounge where the router is located. I think this is where I get confused. I assumed the router needs a cable between it and the NVR box but reading your reply, I'm assuming not..??
I would like to access the footage by an app on my phone if possible. The garage picks up WiFi from the house router no probs.
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #675784 18th Oct 2023 7:12am
Caesium
Try these, they’re budget conscious and I’ve had some of these at my home before I upgraded. They’re not too bad for the cost.
https://foscam.uk.com/fn7108w Christian.
Current Cars
2019 BMW X4
or
Post #675786 18th Oct 2023 7:24am
Rob i have 2 systems, blink cameras and a wired swann system..
the dvr is my lounge and is connected to my router via ethernet cable....the cameras are connected via cable...this dvr is constantly recording and can be accessed via a phone app..i also have a monitor wired up..
the blinks [wireless] are used as motion security cameras... ... - .- -.
Post #675793 18th Oct 2023 8:22am
Gremlin500
If running an ethernet cable is difficult, don’t forget about “Powerline” adapters, various makes (but Netgear is one). These allow you to use your house ring mains to transmit the ethernet signal, just by plugging them in to a mains socket, I‘ve used these for years, and they are faster than wifi “Gigabit ethernet” so good for video. Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #675795 18th Oct 2023 9:32am
Gremlin500
I run a Chinese-made “DaHua” NVR with 4 outdoor cams, it was cheap but it’s been running continuously fault-free for 7 years, and use their excellent “iDMSS Plus” App on our phones/iPads to monitor it, also internally use Blink from Amazon, which is very good as others have said. Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #675797 18th Oct 2023 9:39am
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
just bought a XEGA 4G cam for £100 off amazon. (Xega 4G LTE Cellular Security Camera Solar With SIM Card, Outdoor Wireless No WiFi Security Camera, 2K HD PTZ Night Vision PIR Motion Sensor 2 Way Talk SD&Cloud Storage IP66)
It is excellent, with cloud uploads, solar power panel, no cables (so stand alone), 4g, L/R up/down scan facility, IR and night light, good range and picture.
Price now gone up to £139.
Post #675799 18th Oct 2023 9:54am
DrRob
Thanks all Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #675846 18th Oct 2023 6:48pm
