Home > Maintenance & Mods (L322) > suspension issue |
Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631 |
https://www.gap-diagnostic.com/wordpress/w...lV4.00.pdf
12th Oct 2023 7:05pm |
If there was an issue with the valve block, then I'd expect DTC's to be set - have you got the arm on the height sensor you replaced the correct way round? and for the correct side?
13th Oct 2023 3:41pm |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 456 |
the height sensor was replaced last December and that cured the red flashing marker i was getting on that corner so don't think the height sensor is at fault ...hoping to jack the car up tomorrow and check the valve block -air lines/connectors and wiring (weather depending ).dtc ? do you error codes ? if so i get suspension fault on dash that's it outside of gap tool |
14th Oct 2023 3:51pm |
DTC = Diagnostic Trouble Code = error code
14th Oct 2023 4:27pm |
when i get a chance ill pop them in |
16th Oct 2023 10:08am |
18th Oct 2023 1:08pm |
right on going suspension problems..... one issue now sorted can now change ride heights, how ever over night the car drops on all 4 corners .put to off road height removed eas relay in boot in the morning the front had dropped rear still up (getting somewhere maybe) front valve block or leaking bag or air pipe .....so put the relay back in and i was expecting the back to drop when left overnight but it hasn't,i was expecting the system to off dropped to level its self out anybody know why it didn't ??????
30th Oct 2023 2:21pm |
Right replaced front valve block seals(again) and also fitted new height sensor (genuine)front now stays up π
12th Dec 2023 8:52am |
