![]() | Home > Technical (L322) > Range Rover L322 2011 4.4TDV8 knocking/Rattling |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7881 ![]() ![]() ![]() |
Can’t help directly I’m afraid, but I know that if you take the oil filler cap off, a “normal” one has the odd ticking and noise….
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1481 ![]() ![]() |
It's unlikely to be your chain or chain guides - they're not a known issue on the 4.4 TDV8. There will always be some chain noise from inside the cover (which will of course sound louder with the oil cap off).
Defender Fun Member Since: 10 Apr 2023 Location: Sussex Posts: 29 ![]() ![]() ![]() |
Thank you for your reply’s. Yes I didn’t think it was overly abnormal to have a noise when you remove the oil cap but at a stage now we’re just overthinking anything.
Are injectors common to get loose on these late 4.4’s? |
Surely someone has some information they can give? Any ideas appreciated, really stuck on what to do. |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
Can you upload a video? |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1286 ![]() ![]() ![]() |
Can you not pinpoint the area where the noise is coming from?
Ok so a few ideas:
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1360 ![]() ![]() |
Tapping or rattling?
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4328 ![]() ![]() ![]() |
If you need to get it to a independent specialist then I can highly recommend www.glenrands.co.uk
Thank you for the reply’s guys.
To add,
A garage won't charge much for an injector leak off test. 2015 Range Rover Autobiography 4.4 SDV8 |
Hello everyone
