Home > Technical (L322) > L322 auto lights and wipers
tymh
United Kingdom 2008 Range Rover Vogue TDV8 Tonga Green
Hello sages!
Is this normal behaviour?
I always leave the lights set on auto.
Whenever I start my car the lights come on, then after a minute or so they go off, even at night. Then, if I’ve started up whilst it’s dark, after a minute so of being off, they’ll come on again.
Also,
Auto wipers don’t always work. In fact rarely work. They flip once then do more or less nothing.
Now, I know they’re both controlled by the magic unit next to my mirror, but a) are the lights ‘faulty’? And b) if so, is this connected to the wiper issue? (And c) is this something I can fix myself?) Tym
(current) L322 3.6 TDV8 Vogue 2008 Tonga Green
(previous) L322 4.4 LPG Vogue SE 2003
If it sticks, force it. If it breaks, it needs replacing anyway.
Post #675514 13th Oct 2023 8:16pm
Full-fat-Lance
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Orkney Grey
I wonder if you’ve got an aftermarket windscreen and that’s throwing out the sensors 🤷🏻‍♂️
Post #675517 13th Oct 2023 10:13pm
garyRR
Similar happened on my previous L322. A change of the sensor for a new one yielded the same result. I had to conclude it was the aftermarket screen. 2015 Range Rover Autobiography 4.4 SDV8
Post #675522 14th Oct 2023 6:18am
tymh
I’ve had the car a year and the wipers used to work properly. Only really noticed the lights issues over the last month.
I *do* need a new windscreen as this heating element is broken in places but I think it’s the original. Tym
Post #675528 14th Oct 2023 8:03am
tymh
Where’s the best place to get a new sensor, and are the y difficult to fit please? Tym
Post #675529 14th Oct 2023 8:04am
garyRR
Main dealer for a new sensor, its about £70. Easy to fit - clip off the mirror surround and you'll see it. Unplug the multiplug, use some tooth floss to saw the gel pad behind it to remove it. Clean up any residue with acetone or alcohol cleaner and a plastic scraper, fit the new one. 2015 Range Rover Autobiography 4.4 SDV8
Post #675530 14th Oct 2023 8:08am
tymh
Thanks Tym
Post #675531 14th Oct 2023 8:09am
JayGee
There's also a wiring issue under the drivers seat on the main loom
?si=n9qVfHCIGsvmcPU1 2012 TDV8 Vogue (L322)
Post #675534 14th Oct 2023 8:40am
tymh
I’ve seen that one 😉. However, I’d assumed that as his is next generation that the wiring might be different. Also, mine doesn’t consistently fail. Tym
Post #675535 14th Oct 2023 8:42am
madnessgonemad
My 2012 model had the wiring fault. It’s very easy to check the loom for damage. It could be that your wires are beginning to fail. I would have thought it would be worth checking before you buy the part.
My wipers were completely dead on auto and the headlights only operable in the manual position and the wiring was completely gone.
Post #675544 14th Oct 2023 2:54pm
tymh
My lights work on auto, there’s just a short delay at night. Wipers erratic Tym
Post #675563 14th Oct 2023 10:04pm
