Home > Technical (L322) > Vibration after Drive shaft carrier Bearing Replacement
KennyT
2007 Range Rover Vogue TDV8 Atacama Sand
Hi All,
2011 L322 4.4 TDV8 130K miles
Changed the carrier bearing on the drive shaft and now have a vibration at 52-60mph. No vibration with old worn bearing. Does it need to bed in or am I missing something.
Thanks in advance
Post #675376 12th Oct 2023 8:44am
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
i bet you rotated Cardan joint during assembly.
Post #675382 12th Oct 2023 9:52am
KennyT
Thank you đź‘Ť. I will check
Post #675388 12th Oct 2023 11:43am
dhallworth
That’s the reason that a lot of places won’t replace the bearing and say to replace the entire shaft.
Our local specialist reckon they’ve done a few bearings with no proper success so now they’ll only fit a GKN shaft.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #675464 12th Oct 2023 11:08pm
KennyT
đź‘Ť
Post #676309 24th Oct 2023 2:28pm
