Home > Technical (L322) > Exhaust manifold separation.
Byg Nyge
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
Good day you who know way more than I, your opinions on this. On a recent jaunt to Scotland my '06 L322 TDV8 3.6 developed what I thought was a slipping alternator belt, got worse if the headlights were on. During the holiday it got worse tried to find a local garage in Oban to fix it but no-one wanted to know, it got worse, began to judder and misfire when accelerating to overtake another vehicle black smoke and a high pitched whistle as well, I resorted to driving like Miss Daisy and managed to finish the holiday and get home. Fearing turbo(s) I booked it in to my local LR specialist and was informed that I did have a badly slipping belt but the cause of the power loss/smoke was the exhaust manifold separating from the head, engine out job! Anyone heard of this, the guy reckons it is a known although rare problem with the 3.6
Post #675288 11th Oct 2023 10:47am
Phoenix
Are there any broken exhaust studs? Are you confident in their diagnosis? sounds more like a split inlet manifold to me - to prove either way, a smoke test will be the best way forward. The exhaust manifold can be changed in situ (assuming it's the causal part and not the gasket or the inlet manifold) but if there are any broken studs, these can be easier dealt with by taking the engine out (possibly they are pre-empting broken studs) which would cost more in labour as you've spent a lot of time taking the ex. manifold off 'in situ'.
It's a difficult cost balancing act but you really, really need to be 100% sure of the causal part first.
Post #675308 11th Oct 2023 2:43pm
Byg Nyge
Thanks for your reply, It's at the hands of the garage now, I took it in yesterday and had THE phone call from hell, engine out job. Literally just had a call from them, replaced 4 broken studs and the gaskets all good now - hopefully. Jeez, L322 ownership has it's moments!
Post #675320 11th Oct 2023 3:32pm
Phoenix
It's likely to be a broken stud(s) allowing a venturi to develop through/around the gasket, causing it to break up. The studs can and do break because the manifolds warp - did they check it?
Post #675322 11th Oct 2023 3:37pm
Byg Nyge
It was broken studs, 4 to be exact, 2 came out easily, 2 broke off so close that they had to be drilled out and re-tapped, head face checked and found good and flat, all new gaskets. Should be good to go.
Post #675329 11th Oct 2023 4:20pm
GraemeS
Were the matching studs on the other side also replaced even though they weren't broken? My brother had to remove the body of his 3.6 RRS a few months later to replace the matching studs on the other side.
Post #675341 11th Oct 2023 7:42pm
Byg Nyge
That's a good question, they had the engine out so I'm hoping they would have resolved all issues. Sad
Post #675363 11th Oct 2023 11:43pm
GraemeS
I was surprised that my brother didn't replace all studs both sides when fixing the first lot.
Post #675364 12th Oct 2023 1:10am
Byg Nyge
Both sides were done and mating faces levelled, new gaskets on the manifolds and all pipework joints for want of a better description.
Post #675429 12th Oct 2023 5:13pm
GraemeS
Excellent!
Post #675447 12th Oct 2023 7:39pm
Phoenix
If the repairer did that without prompting, then they know their stuff and did you a favour (albeit one you paid for), well worth giving them your business IMO
Post #675457 12th Oct 2023 8:54pm
Byg Nyge
I found them by accident, we were looking for a new car and it was on route. Called in on spec. re. Engine Management Fault, local guys at a loss, these guys straight out with the diag found the fault, booked in and fixed within 2 days and they didn't charge for the diag session. Been going there ever since for all my L322 woes.
Post #675465 13th Oct 2023 12:14am
