Home > Technical (L405) > L405 ACE Anti Roll Bar Sideways play
Butters
2006 Range Rover Vogue Td6 Java Black
Hey
Does anybody have any experience of an ACE bar being able to slide about 10mm laterally ? You can see the gap and grab it and move it side to side. Is it just bushes or has it somehow lengthened itself? Anybody have any exp on these cheapest replacement is £890 all in so would like to repair if poss..
If you look on the second pic you can see the shiny bit thats how much lateral play we can slide side to side
Is it just the bushes that will stop the knock? Are these supposed to have this much side to side movement ?
Thanks in advance Range Rover Vogue Td6 2006-2010 (Java Black)
Post #675214 9th Oct 2023 11:15pm
Malbro
United Kingdom 2016 Range Rover Autobiography SDV8 Carpathian Grey
There shouldn't be any end play no, the bushes are designed to clamp onto the shaft and work through torsion so it looks like the bushes are done. Not expensive parts but be careful if you are doing the work yourself with the retaining bolts that go into the aluminium chassis as they can seize and snap like mine did Sad
Post #675239 10th Oct 2023 10:53am
