![]() | Home > Technical (L322) > Aftermarket LED tail lights |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Are both number plate lights working? If the fuse blows it takes out a whole sidelight with it and the number plate lights Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 372 ![]() ![]() ![]() |
I got a replacement rear light that is a look alike, it works perfect only difference is that it has the illuminated side lens that is normally just a reflector. I think this is a USA market feature.
SamThomas Member Since: 12 Nov 2021 Location: South East Posts: 293 ![]() ![]() ![]() |
It's a North American option - it may be possible to remove the bulb/disconnect that part of the unit. |
Fullfatfan Member Since: 17 Mar 2023 Location: Sheffield Posts: 6 ![]() ![]() |
Yes all light work ok other than brake light, funnily enough I swapped the units over from one side to another last week just to check wiring loom on the brake light out side and it worked , swapped back to original sides ant brake light worked again ??? Only other thing I’ve done is fitted LED bulbs in reversing light as other are crap, wonder if they affected anything?? I will put original bulbs back and see |
Did it work straight out of the box???? Read that quiet a few have problems and need a wiring modification to work properly |
Yes worked straight away with no need for any programming it cost £103 in June 2021… just checked and can’t get one from same supplier now 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
I’ve just ordered a near side rear light to match the offside with side marker so should have a fully working original 2012 light available if anyone is interested 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Got a link? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
