![]() | Home > Maintenance & Mods (L405) > L405 Park brake fault (Yellow light) |
johnf Member Since: 16 Nov 2012 Location: Nottinghamshire Posts: 84 ![]() ![]() |
Well I've just had my third parking break actuator fail (that said I'm on over 190,000 miles so not too bad I suppose). Luckily happened at home and I managed an easy DIY fix as follows:
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
^^^ I did exactly this a while back.
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 139 ![]() ![]() ![]() |
I'm a bit late to the party on this one.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1680 ![]() ![]() ![]() |
Chris, I don’t think you should have used copper grease? It’s mineral based and may denature the rubber O-ring seal:
Ditto, use Loctite sparingly and keep off rubber & plastic parts, it WILL make a mess of rubber in short order. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
Copper grease is the worst possible to use - you're just adding another metal into the mix...
All very useful to know! |
Mac35 Member Since: 26 Dec 2023 Location: Angus Posts: 13 ![]() ![]() |
Has anyone had a resolution to the issue when a new actuator didn’t fix the issue?
Well I had a twist to the usual problem. Fitted a new brake actuator only for it to fail within a month or so (or so I thought). The replacement didn't work either and on investigation I found that the splined shaft in the caliper had worn to the extent that the actuator was able to spin without moving the brake. A replacement caliper fixed this. At least I have a spare actuator "in stock" now. |
sass Member Since: 23 Apr 2014 Location: Helsinki Posts: 38 ![]() ![]() ![]() |
Got this error on Monday after starting the car again after a 360km drive in misty, salty highway conditions just above 0 degrees celsius.The park brake wasn't engaged. Did a scan on iCarsoft LR 3.0 and got C2007-11, intermittent, right motor.
